upup
I guy told me his flat tyre warning came up, he did replace a tyre. Dealer told him you should have the same tyre, eg both new for sensors to work, I thought there is something measuring pressure
Depends on the method being used, but in no way do you need to be replacing both tyres... So long as the replaced Tyre is the same dimensions as the old one it will work fine.I guy told me his flat tyre warning came up, he did replace a tyre. Dealer told him you should have the same tyre, eg both new for sensors to work, I thought there is something measuring pressure
Where are the, inside the tyre?Those tyre sensor monitors run off batteries, and have to be replaced often too, otherwise they trip warnings on the dash.
And as long as the old one is not worn. They should be ideally be of similar wear levels per axle.Depends on the method being used, but in no way do you need to be replacing both tyres... So long as the replaced Tyre is the same dimensions as the old one it will work fine.
Inside the Tyre yes, but they last a long time, wife's once are 10 years old now. Granted they activate in motion, and the car has low mileage.Where are the, inside the tyre?
Not that fastidious. There was a guy at work that checked his pressures every day at lunch - gave us a huge chuckle. One week, we removed some air from his tyres just to make him fell that his daily check was worth it. Probably will go to hell for that.For almost a decade now of car ownership, I have taken my car once a week to the local Caltex service station near me - usually a early on a weekend morning before I go shopping - as they have digital air pressure displays for their tyre inflation hoses - and I make it a habit to also check the spare tyre as well.
The sticker with the manufacturer recommended tyre pressures for the OEM tyres (175/60R14) is 230 kPa for the front & 190 kPa for the rear tyres, but because I have slightly higher profile tyres fitted (175/65R14) I normally bump up the pressures by another 20 kPa, which seems to improve both the ride & handling characteristics when compared to the OEM settings. I also inflate the spare wheel to 250 kPa as well.
Before I drive out to the service station, I also pop the bonnet & check all the various fluid levels - oil, coolant, power steering, brake master cylinder & windscreen washer - and top any of them up if they are lower than normal.
At the end of this month I will also be taking my car for its 10,000 km tyre condition check - which also includes rotation, balancing & wheel alignment - so that I even out the tread wear on all 4 tyres as equally as possible.
My Mokka has pressure sensors. Only problem is that I rotated the tyres last month when I replaced two and now the front are reading as back and vice versa.my polo gti used to use diameter or something primative. Tiguan has actual pressure sensors. its actually very useful. and great piece of mind when my mrs is driving and im not around.
You should check your tyre pressure when they're cold, iow before you go to the petrol station.For almost a decade now of car ownership, I have taken my car once a week to the local Caltex service station near me - usually a early on a weekend morning before I go shopping - as they have digital air pressure displays for their tyre inflation hoses - and I make it a habit to also check the spare tyre as well.
Agreed yeah.... But you don't automagically need to replace both if one gets a puncture.And as long as the old one is not worn. They should be ideally be of similar wear levels per axle.
