netorius77
- Apr 8, 2013
Someone recently told me that if you have a three phase electricity supply at your house, the meter reads the highest current of any phase and then calculates the kWh based on that current on all phases. He said it is therefore critical that the loads on each phase are as even as possible, otherwise you are paying for energy you are not actually using. This is obviously assuming you have multiple single phase loads across each phase.
Is this correct?
Is this correct?
