How long does B315 power bank last?
Gtx Gaming
Gtx Gaming
cape town
I know the new B315 routers comes with power bank, through my one did not.
I was considering buying one for my B618 router coming soon.
Anybody knows how long the power bank can power the router for?
so far i have had it run for 2 hours and hasnt gone off, power came back. Also its only the black B315 that comes with the powerbank
I have a white B315 that came with the powerbank. I think I got 5 - 6 hours out of a full battery to completely dead
I'll check the manual tonight but I think it's 2 to 3 hours.
Let me know if you're interested in an unused 2nd hand one. I got mine at the end of August, but haven't used it.
Thanx going to see if it will work on b618.
The manual says 2 hours continuous usage or 3 hours of standby.
The power bank has a output voltage of 7.2v where the b618 take power from a 12v plug. That said my B315 power bank works well on my B618
Confirmation:
Hmm, I got the white router and it didn't come with the power bank. Anyone want to sell one?
Morning
I did a upgrade on one of the routers. This one i received a power bank.
At the same time i also did a hardware upgrade and bought a router for R1400 something from Telkom. This one no power bank.:wtf:
Morning
Only some of the versions come with the battery. My B315-936 came with a battery.
I run a telecoms company and I have as many as you like at R50 each. If you buy two you can remove the batteries from one and install them in the other (theres space) and double the time it can run. (At your own risk). Just PM me.
Where are you based?
