JerryMungo
- Jul 18, 2008
As the title asks... Anyone know off hand?
I have heard about Wireshark.
whats more interesting is how they get them there,This is a very interesting topic, not often discussed how they power the repeaters
Shocking!
Volts and Current or not the same thing.The only article I got just says up to 10000 Volts. Current will depend on the repeater requirements.
See here for AC and DC voltageVoltage is the cause and current is its effect. Voltage can exist without current.
Current is the effect (voltage being the cause). Current cannot flow without Voltage.
Submarine power cable - Wikipedia
en.wikipedia.org
Uhhh...aren't undersea cables optic fibre?
The repeaters just receive the diminishing light beams, converts them and sends out new light beams "repeating" the same signals as the diminishing ones.
DC volt drops are noticeable over 50meters, so I doubt they'd use that for transmission of signals. Even RS485 is capped at 500m.
Repeaters are powered by a constant direct current passed down the conductor near the centre of the cable, so all repeaters in a cable are in series. Power feed equipment is installed at the terminal stations. Typically both ends share the current generation with one end providing a positive voltage and the other a negative voltage. A virtual earth point exists roughly halfway along the cable under normal operation. The amplifiers or repeaters derive their power from the potential difference across them. The voltage passed down the cable is often anywhere from 3000 to 15,000VDC at a current of up to 1,100mA, with the current increasing with decreasing voltage; the current at 10,000VDC is up to 1,650mA. Hence the total amount of power sent into the cable is often up to 16.5kW.[34][35]
Ugh. Of course. Sorry, don't mind me - I have the dumb.And where do you think the repeaters gets their power?
Edit: Anyway I found the wiki.
Submarine communications cable - Wikipedia
en.wikipedia.org
