What’s wrong with that charger?yes as long as you arent using that particular charger ,you need fuses and ideally an undervoltage cutout and not really a small battery 18ah minimum
Also asking this.What’s wrong with that charger?
Only gonna need 2-3 hours runtime.The battery bms can do low voltage shutdown when depleted (though might need a jump when power returns with a smart charger that doesn't charge if battery isn't present)
So always nice if you buy capacity that would prevent running it down to shutdown o
How many hours would you need
If 20w leds you will use 3.125AH per hour of runtime
I wouldn't bother with an LFP charger for this setup, just get a lead acid charger.Also asking this.
Coz I researched, and the only other decent LiFePo4 charger I could find on Takealot, is the Victron Blue Smart:
Takealot.com: Online Shopping | SA's leading online store
South Africa's leading online store. Fast, reliable delivery to your door. Many ways to pay. Shop anything you can imagine: TVs, laptops, cellphones, kitchen appliances, toys, books, beauty & more. Shop the mobile app anytime, anywhere.www.takealot.com
www.bravabatteries.com
The charger I posted according to the comments keeps the voltage at 13.8V so will be stress free for the battery. It may charge a bit slower due to the lower voltage but at R300, it’s worth the experiment. You should avoid chargers that keep the voltage at 14.6V forever.![]()
Which is best Way to Charge LiFePO4 Battery?
LiFePO4 battery continues to dominate the battery storage arena in 2023 thanks to their high energy density, compact size, and long cycle life. If you’re looking to prolong your battery life while still maintaining its performance, then knowing the best ways to charge a LiFePO4battery will...www.bravabatteries.com
Yea the 9ah would give that 2 plus and just fall short of the 3 if both are used 100% of the time (if 20w led x2 ) if less watt then more hours of lughtOnly gonna need 2-3 hours runtime.
Don't need the charger as the lights have parallel correction to the battery and will be powered.Maybe the charger wont have continuity when the mains are off so the lights wont work.
IDK, just spitballing.
PS, why not use a decent sized car battery?
Car battery is big, heavy and gives off fumes. Nah.Maybe the charger wont have continuity when the mains are off so the lights wont work.
How much is a decent sized car battery?Maybe the charger wont have continuity when the mains are off so the lights wont work.
You can't run long wire runs with 12V afaik, too much voltage drop.I assume for outdoor use
Can it for indoor use i find the 12v led down lights makes for a clean install
That wat you can lay the wire in the ceiling and just have it come down where the. Battery is
thats an optimate 2 charger ,which is a battery maintainer and charges at a max rate of 0.8 amps .they do a great job on long term standby batteries but dont charge quickly .What’s wrong with that charger?
How could you tell from the pic? There are many flavors of that charger.thats an optimate 2 charger ,which is a battery maintainer and charges at a max rate of 0.8 amps .they do a great job on long term standby batteries but dont charge quickly .
