Ye, that's the one I'm looking at.. The Optimate 2 DUO - TM-550 5-Step 12V / 12.8V 2A - Charger & MaintainerHe's pic is of this one, not the normal Optimate.2.
OptiMate 2 DUO, 2A Battery Charger & Maintainer for all 12/12.8V Cars, Motorcycles and Powersport Batteries - Optimate Battery Charger Shop
Description OptiMate 2 DUO is the 'ALL IN ONE' general purpose battery charger and maintainer that assures batteries are always ready to perform. automatically adapts to the connected battery type – Guarantees healthy lithium or lead-acid batteries! Ideal for batteries found in Harleys, Cars...optimate-battery-charger.co.za
What are the specs of the lights?
That charger will work, but as others have said pretty expensive solution, also think about if you want to add more lights in the future, you might want a beefier system. The reason I went with overspeccing my system is you have enough headroom to cope with whatever stage of loadshedding comes your way and the solar panel is large enough to charge the system fully during the day without having to worry about Eskom.10Watt 12volt Direct Current.
I would definitely get a stronger charger (10A at least) and a bigger Lithium Battery (20AH or so).That charger will work, but as others have said pretty expensive solution, also think about if you want to add more lights in the future, you might want a beefier system. The reason I went with overspeccing my system is you have enough headroom to cope with whatever stage of loadshedding comes your way and the solar panel is large enough to charge the system fully during the day without having to worry about Eskom.
Why would you need 2 hours to charge? You have from sunrise to sunset to recharge.I would definitely get a stronger charger (10A at least) and a bigger Lithium Battery (20AH or so).
Then +-2Hrs later the battery is full if it is nearly fully discharged (which shouldn't really be done).
6Hrs of Backup (@50% DoD for the battery) for both Floodlights.
I am assuming the original setup without solar and worst case scenario i.e. Stage 6Why would you need 2 hours to charge? You have from sunrise to sunset to recharge.
I didn't mean solar, just that the lights wont be used during the day, so the charger has the whole day to recharge but I hear you on the stage 6 though.I am assuming the original setup without solar and worst case scenario i.e. Stage 6
Yeah, I wouldn't run the battery flat.I didn't mean solar, just that the lights wont be used during the day, so the charger has the whole day to recharge but I hear you on the stage 6 though.
You should get 4 hours out of a 7Ah battery with 10W x 2 lights. Battery is 89.6Wh (12.8V x 7). A 2A charger would need 3.5 hours.
He said only wants to run for 2-3 hours.Yeah, I wouldn't run the battery flat.
Ya, but you said 4Hrs, which is not realistic.He said only wants to run for 2-3 hours.
Well, it’s actually 4.5 hours but I said 4 so you don’t run it dead.Ya, but you said 4Hrs, which is not realistic.
And stage 6 is easy 5-7Hrs off in the evening, with short 2-3Hr breaks in between
Perfect so then u are looking at 1.56a for both running10Watt 12volt Direct Current.
your math is right ,for a standard charger ,optimate doesnt work like a standard charger ,they work on a program ,as it states its a maintainer ,so the program decides if it wants to charge at 500 ma for 5 hours then 2 amp for 3 hours etc .you can do better with a standard lith ion battery charger like maybe the Bosch units ,same price .also depending on the battery it may have a max charge rate ,be certsin of that ,otherwise the bms will just waste the excess as heat and clamp your 10 amp charger to 2 amp .but if your heart is set on an optimate go for it ,very good maintainers probably the best on the market .EH? I'm confused then
That charger has the following spec: Charging AMPS: 2A (constant current)
So, I assumed that's its max charging rate.
Or is my maths wrong?![]()
hahaha ,on a 10 watt china led youre gonna get 5 watt of light and 5 watt of heat ,and another 5 watt just because its made kak .Perfect so then u are looking at 1.56a for both running
3hrs would be just under 5ah so the 9ah battery would work perfect can do 4hrs no problem and still have like almost 40% capacity reserve
Or like wingnut said even a 7ah would do as you would use 90% of capacity for a 4hrs stint , he said 3hrs so would use 66% of 7ah capacity
My one charges at 4A (never goes to 5A max for some reason, maybe battery resistance?) constant current until bulk voltage is achieved, then pulses during absorption, then drops to bits of 1A for float (maintenance).your math is right ,for a standard charger ,optimate doesnt work like a standard charger ,they work on a program ,as it states its a maintainer ,so the program decides if it wants to charge at 500 ma for 5 hours then 2 amp for 3 hours etc .you can do better with a standard lith ion battery charger like the Bosch units ,same price .also depending on the battery it may have a max charge rate ,be certsin of that ,otherwise the bms will just waste the excess as heat and clamp your 10 amp charger to 2 amp .but if your heart is set on an optimate go for it ,very good maintainers probably the best on the market .
battery resistance is how the charger determines what composition its made of .optimate does have a specific lith only charger as well ,because it stays at 4 amp means the charger program likes that value to charge at ,other may be 3 amp etc .ie put your charger onto say a lalela and it may charge at 5a or 2amp .My one charges at 4A (never goes to 5A max for some reason, maybe battery resistance?) constant current until bulk voltage is achieved, then pulses during absorption, then drops to bits of 1A for float (maintenance).
