How to auto dial ADSL connection on reboot?
MFour
Hi All
I'm struggeling with this one a bit.
I've copied a shortcut of the DASL dial-up into the start menu, unticked the "ask for UN and PW" option. It works well, reboot the pc and the ADSL dial-up dials in with no problems. However, when I create a user account with a password on WinXP the dial-up will only dial once I have logged in with a Win user account.
What I need then (apparently) is for the PC to auto-dial the connection after a reboot (or once the power has come back on after load shedding :( ), probably by making/installing it as a Win service, or something like that.
Can anyone please assist me with this, as I need to get that pc to reboot and get connected so that the VPN becomes available. Unfortunately it has to be dial-up, and not a router connection.
Much appreciated.
program called adslautoconnect - can install as a windows service - however you need the pc to log into windows automatically (without usernames/passwords) otherwise service doesn't start
Try This...
• If your service provider requires authentication, make sure you have saved the password by checking the Save Password checkbox in the Connect Connection Name window and connecting at least once.
• If you are running Windows 2000, right-click the My Network Places icon on your desktop and select Properties to bring up the Network and Dial-up Connections window.
• If you are running Windows XP/2003, click the Start button, select Control Panel, then click Network and Internet Connections and then click the Network Connections control panel icon to bring up the Network Connections window.
• Locate the Dial-Up connection you created for PPP over Ethernet, right-click it and select Properties.
• Select the Options tab and clear all checkboxes under Dialing options.
• Under Redialing options, set Idle time before hanging up: to never and check the Redial if line is dropped checkbox.
• Click OK to save the changes.
• Now click the Start button, select Settings then Control Panel to open the Control Panel window.
• In the Control Panel window, double-click Scheduled Tasks.
• In the Scheduled Tasks window, double-click Add Scheduled Task.
• On the welcome screen of the Scheduled Task Wizard, click Next.
• At the program selection step, click Browse... and browse to your WINNT\System32 directory (Windows 2000) or to your Windows\System32 directory (Windows XP/2003).
• Type RASPHONE.EXE (note the spelling!) in the File name: edit box or locate it in the directory and select it and click Open.
• Make up a name for this task and under Perform this task: select When my computer starts. Click Next.
• Enter your password. Note: The task must be run under the same account which the dial-up entry was created under.
• At the final step, make sure that Open advanced properties for this task when I click finish is checked and click Finish.
• In the advanced properties, edit the Run: edit box and append the command-line parameters " -d "Connection Name"".
• Go to the Settings tab and clear all checkboxes on that page.
• Click OK to close the task's properties.
• Finally, you need to make a little registry change to prevent Windows from disconnecting when a user logs on and off again:
Run REGEDIT and navigate to:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon
Then right-click the right-hand pane, select New -> String Value, name the value KeepRasConnections and set it to 1.
• Reboot. Windows will establish the connection automatically and keep it until you shut the machine down.
• NOTE: The connection will not be properly terminated when shutting the machine down or rebooting. This can cause problems with service providers who take very long to detect such a dropped connection and limit the number of concurrent connections.
@ MrNutz: Thanks, unfortunately it is crutial for the box to have a password on.
@ mh348: Wow, that's a mounthfull, but will certainly try it tonight. Thanks.
There is another alternative, you can download routesentry, add it to the local machine startup and configure it to automatic dial the connection
Hmm yes I wondered if that would work. Good thanks, I love having options :) Will try that as well.
HAHAHA! I was so waiting for someone to just say this... HAHA! Took so long!
mh348 really does have too much time on his hands ;)
