How to jailbreak iphone 3g with broken power button
jdysolomons
Please could sumbody anybody help me out. im running 4.1 on my iphone 3g and downloaded all the files i need to jailbreak! but my power button/lock button is broken so i cant switch it off as thats one of the steps you need to do.
Feel like sharing the method you used to JB the 3G? :)
It's not too hard to take apart a 3G and try to fix the power button. You need a tiny philips screwdriver to take out the two little screws at the bottom. Then you pop the iPhone open with a suction cup. There are 3 cables which are plugged into the motherboard that you have to disconnect to open it fully. I did it, a little hair-raising but do-able. The one cable is quite fiddly but really it's doable.
I followed the instructions and photos on http://www.ifixit.com/
In the era of the original iPhones, there were some apps (can't think of a name right now) that could put your phone into dfu/recovery mode. I'm sure this might work for you if you don't fancy the idea of opening your iPhone up
