Hi MYBB
I have a pool pump with 4 circuit breakers. I would like to control each circuit breaker independently through wifi. Any suggestions for products to make this pool pump smart?
Thank you
Interested as to why you have 4 circuit breakers on the pool pump? What do they do and what would you want them to do if they were "smart"?Hi MYBB
Thank you
Can I award you 2 friday pointsYep...1 circuit breaker and a timer.
Ive used a sonoff POW to replace the manual timer and give me power usage for my pump. Also used a sonoff basic for the LED light control
same here - have a Sonof POW controlling the pump and a Sonof basic for the pool light.Same - been working fine for years.
Really not trying to be rude, but if you have to ask then perhaps it's better to get someone a bit more experienced to assist you.Going to semi-hijack this thread...
I want to do the same thing - have a Sonoff POW for the job.
Can anyone tell me where to wire it on this DB?View attachment 862671
If only i could automate the pool filter selector!
If you can take and upload a pic of your DB board i'm sure we can point you in the right direction![]()
Why?An automated pool filter selector is a bad idea
In short though - you'll essentially want to remove the timer, so power going TO the timer goes into the POW and power going FROM the timer to the pool pump goes to the outputs on the POW.
Why?
Even though i have replaced the sand a few months ago, the filtration stops after 2hours - a 30 sec backwash clears it after which the pool filters again nicely for 2h or so.
At the moment i have to manually go and stop the pump, change the filter selection to backwash, start pump, wait 30 sec, stop pump, put filter selection back to filtration, then start pump again.
If i could automate this that would save a lot of my time + i could filter the pool when i am not at home![]()
you are just hack fixing a bigger problem, fix it properly, sounds like you have a suction leak.
you also shouldnt backwash with your cleaner plugged in for example.
Suction leak? can you point me in the right direction how to diagnose?
