How to receive MMS while on Roaming?
It is probably possible. It would depend on the capability of the roaming network, and possibly on your APN settings. It may cost a lot - I was once billed about R40 for an MMS when roaming in the USA.
If you really value being contactable on your primary number, go ahead. Cost should not be a factor in this case.
In my case, I'm not willing to pay the roaming costs, so I have prepaid local SIM cards for the countries that I visit regularly.
I would like to know if there is a way to retrieve MMS online since I'm on Roaming, I don't want to pay for excessive data roaming fees.
The only way to do this would be to get the sender to send it to your email. this way you can log on to email perhaps using wifi or local data and view the mms.
