How to share PPPOE connection
bees
Say I want to dial-up a PPPOE connection on my machine, how do I share it with others? Don't know if I'm just dof, but can't think of a way now...
Internet connection sharing in XP?
Or if you have a router let it handle the connection.
u can simply enter your pppoe login details on the router and then connect all your pc's to your router via ethernet/wireless and it should work
Yeah. Normally it's right-click on connection, and then the far right tab, setup the ICS. But my PC doesn't have it?
Full story: We have a router, but it's stuffing around. So now I wanna go the PPPOE route as a temp solution.
Our office is in a domain, maybe that's why I can't do ICS??
Otherwise use Analogx, very simple and easy to use. Id go with Modem mode and individual dial ins...
