Huawei B252-65a Admin fix please !
Kiemo
Hi guys ... does anyone no why I can’t log into admin ?
If I reset the router and I enter my admin user name and password
then after logging out
I can’t log in again because it’s saying error or wrong password ..
Please help
If admin, admin is not working, reset router and use the wps button to login.
is that the wps button on top of the router ?
Plus I did reset the router ... but I can’t always reset it it’s annoying
png.php
The M button ?
telling us how would be helpful
It’s not that the admin don’t work ... it’s just that when you change your admin to something else ... your router ask you so you wanna use your WiFi password as your login password so that you should take note of because if you don’t you can get Lost I had to reset my router all the time to catch that ... so we need to take note told the finer details in life
