EdQubit
- Dec 30, 2006
Hi we have a E620 datacard that we want to use in a Toshiba M70-235 laptop. We installed the MTN software and inserted the card. The problem is when you run the MTN F@stlink program, it just says "detecting datacard" for a while and then "datacard invalid". I can, however, manually create a dial-up connection in Windows using the Huawei as the modem and setting the number to *99#. This works perfectly, it connects to the internet at the correct speeds, you can browse and download, no problem.
The problem is, the company has an APN that we use to connect to the company's internal network. So we need a way to set the APN and the username and password for the connection. Is there anyway to fix the MTN software on the Toshiba or set the APN in Windows, or maybe other software that we can use?
We have tested the datacard in a Mecer laptop and then the software works perfectly.
