dagwood4455
- Oct 13, 2010
a network guy installed a 8-hub switch upstairs in my house yesterday. Attached to this hub was a TV, Bluray player, a mac and a Dlink WAP (wireless access point). I have always had two network cables that go upstairs (modem is downstairs).
This is whole set-up quite a risky thing to have as I have very little knowledge about networks nor multimedia stuff (i just watch them).
Anyway soon after the network guy left I 'just checked he cables' and made tidy. I found a loose network cable, stuck it into the switch/hub and started "enjoying" this new smart tv experience. Then the tv started going on an off, the internet connection of the whole house became intermittent and slow at times.
Eventually I found out that i should not have stuck that loose cable into the switch; you see it was the second cable from the modem / router to upstairs. Now i had two cables of the modem attached to the switch, which caused the problem.
Lesson learned: one should never have two / duplicate cables from a router to a switch/hub.
