Hi All
Upgrading to an i5 2500k and looking to overclock. I'm aiming to push towards 4.6GHz - 4.8GHz on OC. To this end I'm looking for a good CPU cooler that will allow me to keep very stable temps (around 60 degrees Celsius) even under 100% load. Another requirement is a cooler that will be as quiet as possible.
I've heard very good things about the Cooler Master Hyper 212 Plus when it's setup in a Push-Pull configuration but I'm not sure if it will be able to keep temps stable for the i5 if I push it to 4.8GHz. I've heard of guys getting 5Ghz OC using the Hyper but I'm guessing they live in colder countries.
One other thing to consider on my existing rig I do have a Zalman CNPS9900 and was very happy with the performance it gave and would be looking for something similar performance wise on the newer CPU. Unfortunately I'm selling my existing computer on with the cooler and will not be able to simply transplant it.
Budget is around R800 - R900.
Any thoughts/suggestions?
Thanks in advance
Thanks in advance
