fxit_man
Hey guys.
Thinking of building a new i7 PC which will be used for gaming mostly
Can get the following stuff from frontosa @ the following prices.
If anyone has any advice please post!
MOBO: R2 109 excl. (pcint)
ASUS Intel X58, LGA1366, 6.4GT/s QPI, 6xTriple DDR3 2000(O.C), 3xPCI-x16(CrossFire), 1xPCI-x1, 2xPCI, 6xSATAII(Raid 0,1,5,10), 1x eSATA, 1xATA133, Gbe Lan, 8ch-Sound HD, Max 12xUSB, 2xIEEE1394, ATX
CPU: R 2,466 excl. (pcint)
Intel lga1366 i7 920 - Quad core+Hyper-Threading / 8 threads , 2.66ghz box cpu , 4.8GT/s QPi , built-in tripple channel DDR3-1333 memory controler , 45nm - 4x64k L1 + 1mb(4 x 256kb) L2 cache + 8mb L3 cache
RAM: R999 Kingston Hyper-X KHX1600C8D3K3/3GX ( KHX12800D3LLK3/3GX ) , 3x 1Gb/1024mb kit - support Intel XMP ( eXtreme Memory Profiles ) , ddr3-1600, CL8 , 1.65v - 240pin - lifetime warranty
RAM:R898 excl. (pcint)
3 X 2GB DDRIII-1333 (Kingston) @R449excl ea.
GPU: R3 579 excl.
Sapphire HD5870 Game edition , 40nm , HDMi ready , support support DirectX 11 , crossfire-X , built-in HDMi codec+7.1 audio , 1080p HDCP Compliant , pci-e 2.0 x16 , 1Gb 256bit 4 channel DDR5 , 32RoPs , 153Gb/sec memory transfer ; 1600 stream processors ( pixel shader engine + vertex pipelines ) , 80 texture unit , 2.7 TeraFLoPs , core/memory : 850/4800mhz , dvi+D-sub+Hdmi+DisplayPort, HDTV+HDMi tv-out - full retail pack with bundle DiRT2 DirectX11 game coupon
CASE: R1 099 excl.
Antec 900 Two (Nine Hundred Two) with Windowed side panel , black , No psu , bottom placed PSU ; 2 x front usb + audio in/out + 1 x eSATA - 0/3/6/9 x 5.25", 9/6/3/0 x 3.5" hdd , 2 front loaded HDD cages - top-mounted 200mm tri-cool blue fan + 2 x front 120mm blue + 1 x rear 120mm blue + 1x top 200mm blue tri-cool fan upto 6 , quick-release drive cages with rubber grommets , with accessories tray on top
PSU: R1 133 excl.
Antec EA-750 , 80PLUS certified for energy saving , with EPS12V + Modular cable management - 750w , 24pin ( 4pin detachable ) , with active-PFC , 2x6 or 2x6+2x8(6+2)pin PCI-E power connectors , quad 12V rail , 1x 140mm thermal controled fan ; with OVP, OCP, SCP - 3 years warranty , SABS approved
SCREEN: R1,877 excl (pcint)
2494HS 23.6 WIDE TFT, 1920 X 1080 @ 85Hz, 5 Millisecond, 0.27mm dot pitch, 50000:1 Contrast Ratio, D-Sub/DVI/HDMI, Tilt & Swivel Stand
BLU-RAY: R1937 excl.
LG BH08-LS20 blu-ray writer
TOTAL excl: R15416
(TOTAL incl: R17574)
NOTE* I already have 5x Seagate 500GB 3.5" HDD's so they are excluded from the above.
What you think?
- Anyone know where I can get any of these components cheaper? Or are these prices good?
- Will they work together? Compatible etc.
- Any other advice appreciated
Thanks!
GPU: R3 579 excl.
CASE: R1 099 excl.
PSU: R1 133 excl.
TOTAL excl: R15416
What you think?
Thanks!
