I7 system freezing issues
Dohc-WP
ok so i have this small problem with my one pc at the moment and that is it keeps freezing or throwng up blue screens when my screensaver comes on or when i play videos sometimes (the pc never used to do this before. the irony is when i play graphics intensive games it doesnt freeze or when i render complex models and scenes in 3ds and maya it runs perfectly, the trouble only starts when my screensaver comes on which is a 3d screensaver that makes use of the graphics card and its pixel shaders and the sound card but its very far from using the processing power of say crysis or far cry 2, i have already swapped the graphics card with the one in my phenom 2 and it does the same so its not the graphics card, i have also swapped the ram around, removed some dimms etc and it still freezez, if i run a diagnostic like sandra the pc dont freeze,the only possible suspects i can think of is the mobo (temp is usually around 30 -32), the cpu (temp barely goes above 50) or windows (xp pro 64) having some driver issues. what can the problem be
pc specs below :(
I7 975XE
Gigabyte GA-EX58 mboard
6 gigs ram
GeForce GTX285 1GB
Coolermaster 1250W PSU
XP Pro 64
could it be the screen saver it self? try uninstall and reinstall the screen saver
screensaver works fine on my phenom 2 system, the i7 also freezez or bsod when i play certain (not all) videos eg avi or wmv files.
same **** when you remove the codecs ? or and with different pak after a good codec cleaning ?
I'm not saying it's the screensaver itself, it could have been a shyte install, a lot of people don't realise that sometimes a bad install can do some weird things to a pc.
It could also be the video codecs.
OR even the video driver dude, all it takes is a miss placed file or a miss installed code line. So try install latest drivers for graphics
Try restart in safe mode and see if the problem reoccurs.
What's the BSOD error codes? If you get XP to create a minidump you can use MS's debug tools to analyze the file to tell you what file caused it to crash. Otherwise up the mini dump somewhere (it should be approx 64k) and I can analyze it for you.
Are you running the latest mobo firmware/drivers and GPU drivers?
