iBurst Antenna Pigtail
RVQ
Hi Guys,
Where can I get the pigtail (little 30cm or so cable that plugs into the modem and screws on to the antenna cable) for the old white iBurst modem. Sadly the antenna I've got has the pigtail for the new black modems.
Is there a difference between the old and new modems?
Thx
RVQ
just phone iburst, bitch a little and tell them to send you the correct pigtail. Happened to me as well after when i explicitly explained i had the white modem >.>
Yeah do that they NEVER supply everything so call them and make a stink. It's the only way to get things done in South Africa.:D
WTF! The price of the pigtail is more than the entire antenna brand new!
The problem is both the antenna and modem is second hand...
Still fairly expensive (R235) and entire antenna + pigtail is R350.
Gonna give the white modem back and rather just look for one of the newer ones second hand.
