ic asks: please help Doo get more speed...
Doo
Hi there,
I have the speed problem over half month. it still not yet sort out. Anybody can explain for me what's happenning?
Hi there,
I found the international speed slower than 56k modem.
doo whats your numbers like, pings, signal, frame error rate and which base station are you connected to?
sorry for a really stupid question now but are you sure you're not capped?
Hi Slimothy,
Good Afternoon,
Thank you reply my message!
I stay Midrand area. I can see 5 green light on.
Before 2005/May/8, I use Iburst perfectly. after that day. I use it at same place the trouble coming.
and I try external antenna. but the problem still didn't any change. and My friend stay Randburg, Bedfordview have same problem.
Can you tell me how I can do now?
ok i want you to look in your system tray and double click the icon with the IB on it, if its not there go to start -> all programs -> iBurst Termal -> iBurst terminal UTL
then you can get an exact percentage for your signal and frame error rate and come back here and post whatever you find, then go open the command prompt (start -> all programs -> accesories -> command promt) and type ping www.iburst.co.za and tell me the average time for a ping, that will let me and others here better understand your situation.
Also log into the bandwith monitor at http://helpdesk.wbs.co.za and tell us if you still have bandwith remaining on your account, I know it sounds stupid but do it and hopefully we can help
not to be funny or anything but have u checked your spyware ? have u checked if u have any on your machine? maybe a dumb reason but it worked for me as all of a sudden one day i was dead in the water and then i cleaned up and it was much better
Doo ?
is it a UTD or laptop & if UTD (desktop unit) how is it connected : USB or ethernet ?
Hi GuRu,
It is UTD. I try both USB and ethernet. same low speed.
Hi Slimothy and GuRu,
Below is my speed test,
Telkom ADSL Speed Test Meter
Zero
0kB
160kb
20kB
400kb
50kB
800kb
100kB
1.2Mb
150kB
1.6Mb
200kB
2.2Mb
280kB
Extreme!
350kB
Your line speed is approximately 171.5 Kbps or 21 kBytes/sec
( Where kb = kilobits and kB = kiloBytes )
Zero
0kB
160kb
20kB
400kb
50kB
800kb
100kB
1.2Mb
150kB
1.6Mb
200kB
2.2Mb
280kB
Extreme!
350kB
your copy-and-pasting skills suck ;-)
DaveBuchanan1337 said:
and third - person is sooo yesterday
wow i am an embittered forumite...
Dave, i c u don't like the title ic originally chose when creating this thread, ic has added a thread title prefix ;).
Consider this post safe from the horrible, unimaginable problems that the old, 3rd person title could have imposed on Oxford Dictionary Compilers/Lexicographers that perchance could have visited this thread.
Hi Slimothy,
The frame Error Rate from 0.00% to 10.26% up and down.
