Angelus
hi all i just got a proline lcd 19" and iam battling to set the screen colors to what is best, its always to bright or to dark, anyone got suggestions for the ideal screen color settings ie brightness contrast ect
Seconded - if you work with colour its money well spent.If you can afford it get a proper colour calibration system like a Spyder2 or Huey. If not, use Adobe Gamma (if you have Photoshop) or the Nvidia Control Panel (if you have an nVidia card). Both of them can be found in the Control Panel.
Which manufacturer?? If you have a samsung screen you could use magic tune which you can download from the samsung site. Else the spider 2 is a great tool if you are willing to spend the money.
Its very difficult to judge the accuracy of your display without using a meter.I didn't have to adjust the colours on my LCD, just lower the brightness a bit
But NVIDIA's solution is my choice![]()
How badly does it compare to the $58 I paid for the Express?There's a difference between colour accuracy (prints and screen colour match) and colour that just "look nice" to you (more vivid colours but not really accurate).
If you don't work with prints then just use software calibration, otherwise investing in a colorometer is well worth it since you can calibrate multiple displays with it. The damn price of a Spyder in SA is just very 'off-putting' though.![]()
I haven't looked properly but I haven't found it on any SA online stores. Through wantitall you pay about R800 which is about double what you paid.How badly does it compare to the $58 I paid for the Express?
Only if you need it though otherwise its a waste of money. I do a fair bit with photographs and other print work these days and it saves money not having to get things reprinted because my screen was way off. If you dont have to worry about that then calibrate your monitor so that it looks good to you.Yeah, but there's no comparison between colours that I get now and the ones I got with my previous bulky 19" CRT... I'm happy with the colours, according to me they're spot-on. But I get your point, always room for improvement![]()
Only if you need it though otherwise its a waste of money. I do a fair bit with photographs and other print work these days and it saves money not having to get things reprinted because my screen was way off. If you dont have to worry about that then calibrate your monitor so that it looks good to you.![]()
