IDM does not work on firefox4
tofayel521
Hi,
My internet download manager does not work on firefox4.I am trying my level best but I have failed.Would anybody help me?
Regards,
Hi,
Mozilla Firefox 4 browser is faster and better in looks, performance and stability but most Internet Download Manager (IDM) users have one reason not to upgrade — IDM is disabled in Firefox 4. If you're experiencing this problem, here is the solution.You will need to update IDM CC, the Internet Download Manager integration module for Mozilla which intercepts download from Firefox and other Mozilla-based browsers and transfers them to Internet Download Manager using its application programming interface.
idm does not work because older versions are not compatible with firefox 4,just got to firefox on left top corner,click addons,click extensions.remove the idm cc module.now go to http://www.internetdownloadmanager.com/support/firefox_integration.html , do not care reading the page ,just click the install button present at the bottom of the page and restart your browser. See more answer of your question in this link- http://www.techyv.com/questions/internet-download-manager-not-working-firefox-4
Regards,
Josef,
The Flashgot add-on allow any download manager to take care of downloads regardless of compatibility with Firefox. From the same developer as noscript.
I have Firefox 8 plus IDM version 6.07 build 15 and it works great... try reinstallating IDM plugin
