Lupus
- Apr 25, 2006
You have all that power at your finger tipsmost I have ever pulled was 16Kw
Yeah cause building dams is easy, especially for pumped water.Yes, or use the power to pump the water back up to the high dam at drakensberg when demand is low, and use the hydroelectric power when demand is higher.. And.. Build a few more water batteries like this.. Why don't ya..
Or
Stop complaining about everything and do your job.
I could go on..
They employ competent people.. That's for starters..How do other countries that have lots of solar, like Australia, manage?
Pretty much everything is always on, Looking at getting a aircon, maybe 12K btu....You have all that power at your finger tipshave you got nothing that can run during the day to use the sun while it's up?
I personally do not think the previous government found it easy either, but It would be a reality if they started with the extra new hydro and other powerstations and dams many years ago..Yeah cause building dams is easy, especially for pumped water.
They already do use the solar where they can to pump water if necessary.
Something isn't right with those numbers then. I've only got 4.3 installed solar and today with some on and off clouds I've already pulled more than your average.Pretty much everything is always on, Looking at getting a aircon, maybe 12K btu....
Do they? Or could it just be because they have backup from other areas?They employ competent people.. That's for starters..
Well, yes, competent employees would arrange backup too, all in a days work. An unremarkable part of the job.Do they? Or could it just be because they have backup from other areas?
Our backup is the OCGTWell, yes, competent employees would arrange backup too, all in a days work. An unremarkable part of the job.
I dont use alot of power. my geyser averages 1.5Kw per day. fridge and freezer uses 200W maxSomething isn't right with those numbers then. I've only got 4.3 installed solar and today with some on and off clouds I've already pulled more than your average.
Definitely moreWeird it's not showing on the results. Cause you should be easily drawing 21kWh a day with your array
It does indeed seem so, we need to get you a bitcoin miner or somethingI dont use alot of power. my geyser averages 1.5Kw per day. fridge and freezer uses 200W max
That they doDefinitely more
I have a 3.65kwp array and this time of year i do 20kwh ish on sunny day
With 100% utilisation
That is the hard part with bigger arrays having enough load to use it
More batteries solves it at a price though
Get the car first. You likely wont need to upgrade.6.6Kw solar, 10.2 KW battery and 7.2Kw inverter.
Thinking about upgrading the Solar to 30KW for a car.
Do you use any eskom power or is your load just this low?I dont use alot of power. my geyser averages 1.5Kw per day. fridge and freezer uses 200W max
Yea either get the car or more batteriesGet the car first. You likely wont need to upgrade.
