Interesting Note - No LTE Devices Support Telkom Mobiles LTE Network
AFAIK the E3276 that Telkom sells supports 2300MHz TDD.
IMO it is just the specs on their website that is wrong.
Since all their devices connect to their LTE network, we can assume that either:
a.) They're not actually running on 2300MHz
b.) Every spec for every LTE device they list is incorrect
b)
I think that they have listed the specs for the standard versions of those devices, which is incorrect.
there's differant variants of the E3276 & yes their site info is wrong.
The Telkom one is a E3276s-920
The Cellc one is a E3276s-150
Differant freq's on each for LTE
Those 3 ARE devices that Telkom Mobile sells, and the frequencies quoted are directly off their website...
The B593 that I use from TelkomMobile is only working on 2300MHz TDD and not on the frequencies that you listed. Many different versions exist of the same modem. See list below for the different models:
B593u-12: FDD 800/900/1800/2100/2600MHz
B593s-22: TDD 2600 FDD 800/900/1800/2100/2600MHz (Speed to 150Mbps)
B593s-82: TDD 2300/2600MHz
B593s-58: TDD 1900/2300/2600MHz
B593s-58b: TDD 1900/2300MHz
B593u-91: TDD 2300/2600MHz - the one Telkom sells
B593u: LTE FDD 850/900/1800/1900/2600 MHz
B593s: Band 42 (3400-3600MHz)
