Intermittent Afrihost ADSL disconnect issue
Sankekur
I will start off with an apology for being one of "those" guys where your first post is either a problem a complaint, but I decided to post here as a last resort to see if I can either get advice or help to resolve my problem.
To start off with I have a 4meg capped afrihost subscription, my line is also with afrihost (in the end it is still telkom though).
So to the problem. During the second week of September I started having a problem where my ADSL connection would just fall away, after which my ADSL router would struggle for a couple of minutes to regain sync. Just in the general scheme of things it takes a lot longer than normal to regain a connection.
So I gave it a week to see if whatever is wrong gets resolved (Having found with internet problems in the past that with "the 7 stages of internet withdrawal" that it is better for my blood pressure to skip straight to the stage of acceptance).
A week later and no change so I logged a ticket with afrihost, they proceeded to reset the DSLAMs and recreate the port, the normal first response to internet problems. This made no difference, and I informed them of this. I was informed that this was then a line issue and a ticket will be logged with telkom. After the ticket was logged the line stabilized to its normal self for two day, I got a call for telkom asking me it line was working better now. I informed them that I haven't had any issues so far. The dumb sap that I was, I assumed that they had actually done something. Lo and behold, the same day I got the call from telkom the line is disconnecting as it was before. So I contact afrihost again, and they logged another ticket. Got a call from telkom again, this time I was smart enough to know that "Is you line working now?" Is not a question that follows actual work having been done, but more a vain hope that the problem (or client) might have disappeared. So this time I knew enough to say no, my issue has not been resolved. I was told that I would be contacted by an technician. And this is the last I heard from telkom.
Follow this it was just a case of me mailing afrihost and them logging a ticket with telkom or not it is hard say whether afrihost actually logged the tickets or whether telkom was just ignoring me. After a lot of this with no results I logged a ticket with telkom directly, the next day I got sms from telkom saying that my line has been found to be free of defects, and I should a reply so-and-so if I am still having issues, so i did. The next day I got a message saying that I have requested the ticked to be re-logged and to reply so-and-so if I am still having problems.....aaaaand then nothing happened.
All the while I have been attempting to test whether the problem is on my end, to this end I have:
-Tested with 2 extra routers, both showed the same issue.
-I have tested with all the possible combinations with/without filters/splitters I also tested with nothing but the router connected. Also tested with different filters. None of this had any effect.
-I have tested using the other telephone connection in my house as well, was doing the same thing.
-For what it was worth I disable the Wi-Fi in the router, this had no effect.
-I also disconnected all the network cables from the router, this also had no effect.
-I also had a look at the wiring to the telephone plug and all is fine.
-Finally as a last straw I climbed on the roof to have a look at where the wire from the telephone pole connects to the house (now I am well aware that I am not allowed to work on this wiring myself, but if telkom have anything to say about this they should come to me and say it to my face). What i found was that the plastic insulation on both wires was completely perished and the connecting metal and the wiring was badly oxidised, in fact it was so bad that just the movement to inspect the connections the wires broke of. Even though I didn't want to get my hopes up it really seemed like a found my problem, so I redid the connection, and waterproofed and insulated it, aaaaand it did nothing.
With all of this behind me I feel pretty sure that the problem is elsewhere down the line, but telkom just refuse to do anything by ignoring or just saying the line was tested it is fine.
Speaking of testing the line I was lucky enough to be able to call in a favour from a friend that works at telkom to get test result from telkom on my line (he did however say he cannot do more than that as it has to go though the proper channels)
This is what the test results for a week in October looked like:
So am not sure who did the testing on my line when they told me it is free of defects, but it is clear this person is either incompetent or a liar.
And that is the sad state of affairs. It has now been made abundantly clear to me that I am the only person that wants my internet to work properly, and both afrihost and telkom are perfectly happy with the situation as it is, with me paying them every month. Though if I can't find a resolve for this soon I will be putting an end to this free money giveaway.
I am hoping someone here has some help or insight to share.
I can definitely understand your frustration, and I hope that we can find a way to resolve this.
I've also got your PM and we'll go through this together to hopefully find a solution to this :(
Thank you for your response.
That is the problem i am having.....I can't seem to get telkom to send out a technician.
I am hoping I can get this sorted
I have the exact same problem! With Webafrica / MWEB / Openweb I've never had this problem.
Switch to Afrihost, BOOM. Random disconnects. I'm talking about the line completely dropping. It's so annoying when you playing comp in CS:GO.
I rate I'm going to leave them, apply for that double-your-money-back ( I've been with them for a month - capped ), and just go back to AXESS or someone else.
Afrihost is a good ISP. They have excellent Customer Support. But I cannot deal with this.
In the same boat of AH. Support rules, but the issue will not go away :(
So frustrated at the moment I am starting to respond to them like a flippen docker...
I have the exact same problem. It has been a month now and still Telkom is too dumb to fix the problem. I am with AH but my line is still with Telkom so I have to deal directly with Telkom. Now numerous tickets have been opened and closed but the problem is still there. You open a ticket, the don’t come to your house, they send a sms stating it is resolved, you phone the call centre and they tell you there is a problem on your line literally 5 minutes after the sms was received so how furking clueless is these people actually?
I did the exact same tests as you have to ensure that the fault is not on my side, before phoning Telkom, and yet the first thing they ask you is if you turned your router off and on again?? Seriously?!? My line attenuation jumped from +-47 to 60 and my SNR dropped from 16 to 6 (ok sometimes at least it is 6.3). I can’t open my email same as you. My line is syncing at 3069/506 yet it is supposed to be 4meg. I am fully aware of the fact that you don’t always get 4meg, but it should still sync at 4meg, not 3meg. It was running STABLE at 4meg in the past, yet they can’t (or what I personally think, are too stupid to) solve my line problem.
Don’t think that if they send a techie to your house the problem will be fixed (at least not where I live), since there has been 3 to my house, but they don’t know jack ****, they normally come to your house at 15:30 then test the line, tell you it is faulty but the guy at the exchange is leaving now so they will have to return the following day, then the following day you receive an sms stating the problem has been resolved....
If I take my router to my friend’s house, everything connects perfectly hell I can even watch YouTube vids without buffering. What I don’t understand is that sometimes when I do a speed test it states 2.6D and 0.9U but I can’t even open my email, then I get results like 0.06D (not kidding) and 0.20U.... I do not know who to talk to anymore, since they all seem like a bunch of illiterate buffoons, and I ran out of patience this weekend while sitting at home trying to connect through my cell phone data with little luck as well.
Now I am a paying customer, and I paid for that copper line for 10 years now, I loooong time ago paid enough money for you to replace that old piece of **** copper line with a new one or with fibre (please fibre?!?!?!), and I just refuse to pay another cent till my line is fixed. I don’t get service, they don’t get money!!
Oops forgot that this was a thread aimed at AH, just saw Telkom somewhere and went red lol. My problem is not AH as far as my knowledge goes, so soz for flaming in the wrong thread.
I have the AfriHost (CellC) "Fixed Mobile" 20GB capped data contract, and it resets exactly every 59 minutes 59 seconds.
Does other users have the same issue? Based in Northern suburbs Cape town.
Very frustrating ( and eating my data) when iOS updates bombs out after 2.2GB
