Highlander
- Jul 31, 2006
Originally posted this in software... but this might be a more appropriate place....
Been having this problem for the past couple of weeks.
I'll start browsing happily on a couple of sites, then all of a sudden, will get a page cannot be displayed error. I'll then refresh, either once or up to 10 times and the page will load. Sometimes not all the data on the page, but if I refresh again, it eventually does all load. Other times the same pages load first time perfectly. There is no pattern, i.e. happens on local and international sites, and on some occassions links will work fine and on others, those same links won't. The error happens instantaneously, i.e. no loading time so suspect it might be a DNS issue.
It happens with both IE8 and Firefox, but from what I can tell, only over wireless. The wireless connection is strong.
I also never lose connection to MSN, Skype, Voip client, and a continuous ping for IP or domain name never times out or interrupts. uTorrent also doesn't seem to drop any speed during this time.
I'm running XP and its on a Samsung Netbook, and SP3.
So whats changes since I last noticed it working perfectly. Some windows updates, updated the wireless driver - Atheros adapter (tried rolling back, but no difference). Also installed uTorrent, but the computer crashed right at the end. uTorrent works perfectly though, so didn't think this would affect it.
I've found some info regarding a Winsock and TCP/IP reset, but quite apprehensive to try this as I don't fully understand the implications.
Wireless Router/ modem is a Dlink DSL-2640u. I've updated the firmware, but that hasn't helped either.
My main PC connected via a network cable has never had this problem. If it is DNS, surely this would affect both the main PC and the wireless netbook - or does DNS behave differently over wireless.
Any suggestions would be hugely welcome as this is irritating me.
Just also experienced this issue while going to the router setup page, i.e. via the gateway IP address, so maybe not DNS.... er....help!
