Inverter and Lithium Battery
Slamz
In a Galaxy not so Far Far Away
Hi All
So I’m thinking of getting the inverter below(coz my neighbour has one and it’s silent and works)
https://pvstore.co.za/products/synapse-offgrid-inverter-3kw-24v-dc-1000w-mppt
Now he has 2 x 200ah gel batteries and is happy with it, but I want to go lithium coz long term cycle life etc
So I was thinking of below
https://bshockedelectrical.co.za/p...ariant=42051052241068&ptcid=43931_1_692439053
I’ve read somewhere that these lithium batteries are not compatible with some inverters, and I’m totally clueless to this, so any experts here can advise what to do? Btw, not looking for things more expensive than these ones, got some budget for this
It will i have used that exact battery on that type of inverter.
That battery super cheap wonder if they have stock.
Thanks, I’ll check on Monday if they have stock…
How many hrs did the battery last through loadshedding? I just need it for the freezer, tv and running a laptop, screen etc…
Thinks it’s a good idea to get this or 2 x 200ah gel batteries?
Very bad iead to get gel batteries.
Cant really say how long it will last, depends on specs of laptop, freezer etc.
My house only requires 350watt with everything running inc 2 freezer, but this excludes anything in kitched or pc/laptop running. So it will do easily 4 hours with battery to spare.
My main power drawer would be if want use mcirowave or use laptop/pc at full performance.
My 2 48v 100ah lifepos hold me for 12 hours, but my average draw is 400w.
Apart from its lifecycle and other reason? I’m trying to outweigh pros and cons
For what I intend to use I’d probably be using about 400w max, so something that will last me 4 hrs will be ideal for the stage 5 and above LS
You'll replace them in less then a year at this current LS
