REAPER
- Oct 4, 2016
Hi Guys
I need you'll to recommend what inverter and how many Ah battery I need to power my computer during load shedding.
This is my computer - https://support.hp.com/ca-en/document/c03832938
It should be 320w power supply and I have 2 monitors which is 20w each.
I only need to power it for 2 hours. I don't want something very expensive, otherwise I rather add a little more money and buy a laptop. Basically I want the cheapest option that will work.
I don't know anything about what to look for so any advice will be appreciated.
