RedViking
Nord of the South
Yeah. I learned I don't have enough money.Have a browse through powerfuorum.co.za. I've learned lots there.
all we want to power is the freezer charge phones router and laptopsIts hard to recommend something if we dont know what devices and how many. You mentioned freezer which means you need a true sine wave inverter and a bit bigger as the startup current will be higher but we have no idea of the others.
are they badEllies. Yuck.
lithium will last 10+ years, lead acid probably a year.so the more cycles a battery can do the better it is am i right the price on it is good
I got into kuk when I recommended clearline.Ellies. Yuck.
I don't know. I just always known Clearline to be the superior one. Ellies have failed before. Clearline seem to outlast. Maybe someone lied. Maybe just luck (or badluck).are they bad
You get what you pay for.I don't know. I just always known Clearline to be the superior one. Ellies have failed before. Clearline seem to outlast. Maybe someone lied. Maybe just luck (or badluck).
Like others have said. No point in powering freezer just during loadshedding. Sure, spend 3 times the money if you want to, or just use the refrigerator surge plug which protects it from damage, and just get a 12V setup I suggested earlier for a TV/laptop/computer.One of these with the lithium upgrade will give you some good use. Not sure if its in budget but the stage 4-6 is killer on batteries so adding 2 solar panels at some stage will save you a good amount of cycles.
3000VA Mecer Axpert Pure Sine Inverter + 2x 100Ah Battery Trolley (8 HOUR BATTERY LIFE) KIT - 3000W (150-200 cycles)
Inverter: Mecer Axpert Type 3000VA (3000W) PURE Sine Wave Inverter (1200W PWM Solar Controller) Batteries: 2x 100Ah Lead Acid Batteries (Royal/Delkor/Enertec/Energizer) Cabinet: Geewiz Black Powder Coated Steel Cabinet + Wheels All cabling and connectors included Unit Dimensions(l,w,h): 39.5 x...www.geewiz.co.za
A better plan is to get a killawatt first and measure your devices to see what the peak watts is and how many Wh is used.
The 600W PSW and Hubble S-120 I posted earlier should take care of all that, except the freezer.He also added laptops to the list. So freezer, laptops, cellphones. Multiples of those can chew quite a bit of power.
Either way he has some options, personally I would just bite the bullet and get a bigger one now as loadshedding isn't going anywhere.
