SwaarMetaal
Hi, please help!
I'm looking at buying this (or something similar to this):
www.geewiz.co.za
I'm willing to add more batteries if needed.
Now, this is the maximum amount of items that I would like to connect:
50cm floor standing fans (for the Pretoria heat) X2
65 inch TV X1
Game console X1
55 inch TV X1
Android TV box X1
Router X1
Fibre ONT X1
This is around 500 / 550W if I'm not mistaken.
Will this setup be sufficient and also, will it be able to run for 2 hours?
Is GeeWiz recommended? If not, where else can I buy something like this?
Any help will be much appreciated!
2400VA Mecer Inverter + 2x 100AH Batteries Trolley (8 HOUR BATTERY LIFE) KIT - 1440W (150-200 cycles) - 12 Month Warranty
Inverter: Mecer Inverter 2400VA (1440W) + 20A UPS Charger Batteries: 2x 100Ah Lead Acid Batteries (Royal/Delkor/Enertec/Energizer) Cabinet: Geewiz Black Powder Coated Steel Cabinet + Wheels All cabling and connectors included Unit Dimensions: 44cm(H) x 39cm(W) x 38cm(L) 12-month warranty on the...
65 inch TV X1
Game console X1
55 inch TV X1
Android TV box X1
Router X1
Fibre ONT X1
