iOS 5 major problem
Latif786
Hi guys
I was browsing through cydia last night and i downloaded something called afc2usb or similiar. It said at the bottom after installing the file reboot the device so i clicked it.(My device is tethered jailbreak Iphone 4 with iOS 5) As it was restarting it got start on those dots moving in a circle and it wont go further than that. Really need help
Hi Latif786,
Just click Restore in iTunes, or right click on the device and click restore from backup - this aught to re-set the device.
Hey tnx
but forgot its a teathered jailbreak unlike my OS4 jailbreak so i have to start up redsnow and go to the just boot option and it works perfect dan.
Tnx anyway
yeah , i had the same problem !!
i tried to re-run the jb and still didnt boot , so i had to restored my jb ipsw and then run ibooty again , sad!
really hope the untethered comes soon
Quite a few cydia apps are not ios5 compatible yet. I had to learn this the hard way three times :P
Look into semitether though - a BigBoss app that lets your phone at least boot if it's not tethered. Not much works, but you can make phone calls and receive SMSs...
Hi guys
This has nothing to do with iOS 5, the fact that this happened is purely your fault as Cydia apps are not yet optimized for iOS5 and tethered jailbreaks become a nightmare when you start installing apps such as springboard that constantly restarts your iPhone.
By the sound of your knowledge regarding Cydia and jailbreaking I suggest you avoid using Cydia altogether(or atleast till the untethered jailbreak is out). Messing with Cydia with a tethered jailbreak is going to result in lots of restores and with the compatibility issues between 4 and 5 you run a greater risk of bricking your iPhone.
My 2c
