Pada
Hi,
I'm having a problem with my ADSL in Stellenbosch, which only started a few days ago, where the IP packets would drop for like 5 seconds like once every 4 minutes.
Even my PPTP VPN to my office would disconnect too.
My PPPoE connections (IS & WebAfrica) doesn't drop. My SNR margins sits on 20dB down & 13dB up with my 4Mbps ADSL connection.
My ADSL's current uptime is about 50 hours, where it never disconnected even once in a month!
When I ping the first hops on both the IS & WebAfrica connections, they would drop at the same time:
I find this very annoying, because now I basically can't play Bad Company 2 any more
Code:
Reply from 196.209.22.1: bytes=32 time=30ms TTL=254
Reply from 196.209.22.1: bytes=32 time=31ms TTL=254
Reply from 196.209.22.1: bytes=32 time=32ms TTL=254
Request timed out.
Request timed out.
Request timed out.
Code:
Reply from 41.185.86.1: bytes=32 time=12ms TTL=254
Reply from 41.185.86.1: bytes=32 time=11ms TTL=254
Request timed out.
Request timed out.
Request timed out.
Reply from 41.185.86.1: bytes=32 time=13ms TTL=254
