ipad mini battery problem
Nolois
Hi
I need to ask if anyone has experienced a weird battery drain from an ipad,
and how they where able to fix it.
My ipad has been updated to OS7.0.4 for about month now
yesterday my battery started to drain power faster then normal
in sleep mode... I don't know what is the cause of this new problem.
I fully charged the tablet since the was no charge......
to only experience the weird battery drain.
The ipad usually last me about four days of use. since
i switch the 3g on when i use it, and off when it is sleep mode
Could be a one / few new App that supports either Background Refresh APIs or Notifications as both these features allow your Apps to run in the background, even while sleeping.
To check if this could be the cause; I suggest temporarily turning it off:
Settings -> General -> Background App Refresh -> (turn off the main slider, Shown as Background App Refresh)
Re App notification; when a notification is received, that App is allowed to wake up and run some operations, and this will happen each time a notification is received (btw some notifications can be completely silent -- used for background updates). If you suspect it could be this, then try to isolate it per App, by disabling the feature in Settings -> General -> Notification Center -> (choose a specific App to disable notifications)
