iPhone 14 battery discharging while plugged in
Tim_vb
Southern Capeberg
this morning it seems my phone 14 on ios18, battery discharged while plugged in to the 2A charger overnight. Has anyone else seem something like this?
Happened to my iPad twice in the past, I think the connection conked out and made the software not take the charge while thinking it did. Only replugged to charge again and never happened for years again.
Hopefully it's the same with you or some lint, worst case the cable.
Try restarting it and see if that helps.
Did you buy your charger from Iqbal at the local tiny spaza shop for R99?
