iPhone 5 passcode and pin order
Nissan23
I wonder if anyone else experiences this. When I turn on my iPhone 5 with Vodacom sim on, it says no service at the top left where it should say vodacom. Then I enter my passcode. Then it says no service for a few seconds and then the popup comes to hit unlock and I enter my pin. As I enter my pin it still says no service for a few seconds and then it says searching and finally Vodacom appears.
While this is just a mild annoyance, my iPhone 4 never used to say searching. Locally it would pick up Vodacom immediately. Do you think this is because Vodacom is still sorting out the iPhone 5 or because I used the phone in the UK with another sim and it still has some other carrier settings somewhere?
Any advice or tips?
Have you tried restoring the phone just to make sure?
Have you tried turning it off and on again?
My iPhone 4S says searching all the time - really depends on where in the network you're at.
