phly
- Mar 13, 2013
After getting and using a Macbook for sometime I saw the light and decided to invest in an iPhone 5s. It is a simple 2nd hand one and not new and so I have some slight issues already. The back story is a very sad one that I will not waste time going into it. I got it in "good" condition though. Not locked or anything and have been able to set it up and put my apps and basically use it as my daily driver. One issue though of concern is my battery/battery indicator seems to be acting up.
I would have the phone at say 100% and as long as i don't it, it remains there. Standby time is very good. Slight use however i will see 99% then before i know it 93%. It will discharge in such a manner. attimes behaving for some time discharging normally the erratically do a massive drop like from 90% to 83% and before i know it i'm in the 70% region.
Does this mean my battery is at fault or the phone is at fault? The phone itself seems to function fine and the main issue i have seen beside this battery issue is the phone would freeze momentarily and not respond unless i press the top power button once then press it again. (basically put it into sleep mode and out of sleep mode.)
Should I be worried/concerned. Is there a remedy for such? Other than that its my first iPhone and so far everything works as expected and i'm enjoying it.
