Hello all.
Over past several months, my data usage has been climbing uncharacteristically.
After emailing one of the developers with bug reports (Greg Pearce, Agile Tortoise = Drafts), it appears my phone has been playing cowboy with the Background App Refresh, and being far more chatty than usual. It most likely explains my high data costs.
[By example, since December last year, Drafts alone has used over 87mb of data - and that's a simple Text-only sync, where my Dropbox folder that Drafts syncs to, is a whopping 124kb in size!]
Things appear to be getting worse, with the latest consequence being battery life - presumably as activity is still continuing on in the background. Last night, at friends, my phone dropped 40% in very little time, and was virtually dead on getting home. Popped it on the charger, and had it back at 57% before turning off the lights at close to midnight - this morning, it was so dead it couldn't switch on. That has never happened before.
Question--
In light of the above, should I:
A.) Wipe and do clean install?
B.) Wipe and install from iTunes backup?
C.) Simply Reset All Settings (as opposed to a wipe)?
D.) Clean install and systematically introduce apps, one by one, to try and isolate the issue?
Thoughts?
Question--
Thoughts?
