iPhone - EDGE / GPRS help?
runforrestrun
I've recently bought an iPhone, had it unlocked and am currently using an O2 pay as you go SIM card. However, I am unable to browse the internet or use any applications requiring EDGE. I've heard that there is a bolt on for O2 PAYG cards, that allows internet access. I ordered that bolt on, it's here. But I still cannot browse the internet. It says I have not subscribed to EDGE.
I am unable to get a contracted SIM card, which would surely allow GPRS or EDGE.
Is there a way for me to have internet access through my iPhone, by means of EDGE or GPRS? Whichever way, it doesn't matter, as long as I can start using half of my iPhone's applications again. Is there a setting I've missed that allows my O2 bolt on to work?
Thanks in advance.
I could've helped you with MTN/Vodacom/Cell C/Virgin.
Not familiar with O2.Try a local forum
You need to goto Settings, Network, Edge, and then type in operator provided info. Goto an O2 store...they can help!
