All GSM technologies 2G (GPRS/EDGE), 3G-WCDMA (3G/HSPA) support simultaneous data (PS) and voice connection (CS). LTE works different, as it doesn't support CS services but you don't lose data connection on LTE during voice calls either. As opposed to EvDO CDMA technology (used by Neotel so far) which do not support it.EDGE does not support simultaneous data + call.
3G should
I think LTE doesn't even support calls, so you might well lose your LTE connection when a call comes in?
Speed reduction and losing 3G completely can be attributed to battery problem. When voltage drops below certain level, device will reduce data transmition rate to maintain voice connection. Even 3G modems do this when USB cable is not supplying sufficient power.Its usually network related. I noticed that some devices on Cellc and 8ta when on full 3G will sometimes kick you back to 2G during the call. That could cause you to lose connection.
Also I did run some tests but when a call is active the 3G speeds gets reduced so much basically only whatsapp and bbm messages goes through. Web pages are slow to load.
On 8TA it happens all the time for me. The moment we get a call, the 3G drops to edge and I am unable to access any website.
Right, when more people are experiencing this problem, then there is possibility that tower kicks you out. Is the same happen in different area in good signal condition?
