techead
everything setup, working fine.
channel 1 - 1 x 120mm 1000rpm on Corsair H50 rad
channel 2 - 2 x 140mm 1000rpm
channel 3 - 1 x 140mm 1000rpm
all the fans above are Thermalright X-Silent series
Everything reporting correct speed, etc etc
I decided I want more flexibility on the CPU rad, so I plugged in a thermalright FDB 2000rpm.
PC starts up, and firstly the LCD doesnt report the RPM of the channel its on. Second thing, its stuck in a loop or 3 speed settings.
Pc starts -> 2000rpm ->500rpm ->1200rpm ->2000rpm (rinse, repeat over and over and over.....)
I plug the fan into other channels, same thing. I plug the fan into CHA01 and it works fine.
Any ideas?
Any ideas?
