iTunes not starting...
PHTech
Witbank
I have iTunes installed on one of my client's PC.
When I want to open iTunes, it shows activity on the HDD, but after a short while, the activity stops, but no opened up iTunes. . . ?
It shows a process in Task manager, but cannot find it running somewhere...
I have installed iTunes 7.6.0.29. . . I have also tried 7.2, but still nothing...?
Anyone experienced that problem before...?
Your library is probably corrupt. I think it's called iTunes.lib and it's somewhere under your document and settings folder. Delete that file and try again.
Right Click on the itunes process(iTunes.exe) and press "End process tree" then after it ends the process try to open iTunes
Why don't u post iTunes issues in the mac section, it's quiet there and you'll get more help.
It's probably a Windows machine :)
As far as your problem, the only thing I can think of is too remove every reference to iTunes, and then reinstall it...:(
