wordhog
Is it just me, or is something very wrong with the Vodacom network just recently? I've been getting increasingly frustrated in the last week or so.
Problem 1:
Although I can generally connect OK, it's often slower to connect than it used to be.
Problem 2:
I keep getting disconnected. The error code is normally RAS error code 631. This can be as many as 40 times an hour.
Problem 3:
When I try to reconnect, it often wants me to connect to GPRS Roaming - I've never roamed and don't intend to.
Problem 4:
I used to be able to connect at either 3G or HSDPA when I took my laptop to town (I only get GPRS at home). Now when I go to town I usually seem to get GPRS. If I get 3G or HSDPA, it usually disconnects before I can take advantage of it!
Problem 5:
None of the above is consistent. Some days I can connect first time, stay connected for an hour, get good (even unusually good) speeds. Other days I feel like slitting my wrists - I just can't work at all. The only thing that is consistent is that disconnects and slow speeds seem to go together.
Setup:
Unchanged in the last few months - Windows XP, Huawei E272 with Mobile Connect Lite 9.3.0.8940 (not sure about firmware but it's been working fine until the last few weeks). My husband is using the same setup and is having the same problems as me.
I've googled the problem and I saw that VMCLite 9.3 is recommended for this situation. Before I waste valuable bandwidth and time doing this, is it likely to work?
TIA!
Problem 1:
Problem 2:
Problem 3:
Problem 4:
Problem 5:
Setup:
TIA!
