KEF HTB2SE Powered Subwoofer
rpm
Admin
Staff member
Johannesburg
by: beemerstyle
Description: This unit is an ex display unit in "new" condition repackaged in original box Looking for something a bit different in the subwoofer department? Then this is for you! The stunning KEF HTB2 will sit nicely behind your sofa due to it thin stand-up design but it looks so good you probably wont want to hide it! The KEF HTB2 is not just all show and no go the 250W digital amplifier powers this subwoofer to give astonishing deep low bass despite its relatively small enclosure. KEF's Comments: KEF HTB2SE is a subwoofer that looks so good you'll want to show it off instead of hiding it behind the TV or the sofa. With its Ultra-reliable high efficiency 250W class D amplifier the Kef HTB2se Plays very loud and clean all day long, if necessary. The 10 inch driver with matching passive bass radiator ensures that the surprisingly small enclosure reaches down to the lower frequency's to give astonishing deep bass allowing it to deliver both awesome movie effects and yet be subtle musicality. The Kef HTB2se can be very flexible when it comes to positioning it in your room. Depending on your space requirement or your visual preference it can be left vertical or laid out horizontally. The HTB2se unique design is acoustically inert which means that they'll be no nasty buzzes or rattles when driven hard. Features: Ultra-reliable high efficiency 250W class D amplifier. Plays very loud and clean all day long, if necessary. 250mm (10in.) driver with matching passive bass radiator. This configuration ensures that the surprisingly small enclosure reaches down to give astonishing deep bass, and can deliver both awesome movie effects and subtle musicality, as needed. Flexible positioning. Depending on your space requirement or your visual preference, vertical or horizontal orientation is possible. Acoustically inert enclosure shaped to eliminate internal standing waves. In a nutshell, no nasty buzzes or rattles when driven hard. SmartBass 'connect and go' feature for simplicity of set up. Our engineers have carefully designed HTB2 to be as simple and practical as possible; just connect it to the mains and your AV receiver to be assured of optimum performance without the hassle of "tweaking". Sub frequency response: 30Hz - 250Hz Maximum Output: 110dB SPL @ 1m Sensitivity: 100mV for full output High Gloss Black Dimensions: H390 x W440 x D195 mm Weight: 11.3Kg Contact Warren on 083 308 6176 or reply via mail
