Jonny Two Shoes
If anyone can save me from this frustration which is about to force me to stop playing it will be much appreciated.
I used to play BF2 fine quite a while back. I now decided to get back into the game again but it is lagging quite strangely.
I am constantly being teleported short spaces or I lose control and it usually lasts about a second or two at random. I would expect this to be seen when your ping gets pretty high but while it's happening I quickly press TAB and note my ping can be around 25-50ms while it happens. Sometimes my ping does spike but I can't attribute it 100% to the teleporting lag like issue.
It is causing me to get killed on countless occasions as well and normally I would not take a small bit of lag seriously but this happens way too often and is getting on my nerves. Conveniently it will always happen when I need to aim properly or run away quickly and I find myself struggling to use the sniper scope or running into walls from a short teleport only to be impossibly killed from my last known location or where I was standing a second before.
Anyone else experience this or know where the problem could be?? It's like I am not synchronising with the server sometimes. Could it be a punkbuster issue? I could say it averages once every 20 seconds or so.
I have tried dual core patches and tcp optimizer and tested here and there but can't fix it. I have also reinstalled PunkBuster, no joy.
