LAN cable connection via router to internet
solantis
I've got a wifi router conneted to my OTP and a wifi dongle in my PC that connects it to the internet. I also have a LAN cable from the same PC that goes into another router where my LAN and printers are connected too. My question is, how can I connect my PC to the internet using a LAN cable and not Wifi dongle? Note that I cannot plug my PC into the ONT because the wifi router is connected to it which the other devices in my home require.
Hope im making sense and sorry I assumed this is the most appropriate board to post the question.
Plug your PC into the router where your printers are via ethernet.
If thats not possible buy a switch and connect the switch to your ONT where the wifi router is.
My PC is plugged into the router where the printer is. Should I connect that router to the router that is connected to the ONT?
You can , but need to disable dhcp on the router connected to pc + printer , before linking the 2
