Lan Hubs..
LiengLiengZA
Dronkenville,Vereeniging
I have a 8-port 10/100 Lan hub.I can get another 8 port hub but the trouble is that we are 13 guys that's gonna LAN.Can one perhaps "bridge" the 2 two hubs together or is there another workaround?
As Spiderz said ...
Though I have found that in a lot of cases even that is not necessary -- just try daisy chain the 2 together, i.e plug one normal cable from one hub to the other hub.
Hopefully it's switches and not routers, but that's a discussion for another thread, but even the el-cheapo Mecer switches I have, have enough autosensing to just make it work ...
I currently have a Billion modem plugged into a Mecer switch plugged into a Dlink switch connecting all the devices in my house -- all normal Cat5 cables, no cross-overs.
as long as it says AUTO MDI/MDIX, you can use a "normal" network cable, otherwise you will have to get a crossover cable.
