guang
I always plug the power adapter when I am at home, will this reduce the battery's life?
What you always do about this?
To me that would be madness - esp in SA. I probably do a deep discharge every few months but its rarely intentional.Some people take out the battery and connect it to the mains if they are at home. It is said to help w/ battery lifespan...but I dunno.
Read my post again...was a bit ambiguous. By "it" I meant the laptop.To me that would be madness - esp in SA. I probably do a deep discharge every few months but its rarely intentional.
And Eskom comes along and does its thing and then what do you have? I knew exactly what you meant I just dont believe its a good idea at all - at least not for the sake of a battery.Read my post again...was a bit ambiguous. By "it" I meant the laptop.
i.e. Remove battery from laptop and then connect laptop to the wall socket.
ETA: fixed above post.
I doubt that the laptop battery will save your laptop. afaik laptops work more like off-line UPS than on-line UPSs.And Eskom comes along and does its thing and then what do you have? I knew exactly what you meant I just dont believe its a good idea at all - at least not for the sake of a battery.
