www.is.co.za are under severe strain they are not involved in ADSL..ect. Ian at www.is.co.za told me he would allow the transmission of data from their peering points with a LASER BEEM
or parabolic. Mircrowave has fresnel zone issues and ofcourse a parabolic on the roof would alert the regulator. A laser beam (data > 10meg) can't be seen. The transmitter can be plastered into the wall on the peering point or installed behind a window. The range is 5km.
This is a foolproof system to get data out of an ISP..because nobody will know about it!
http://www.lase.de/produkte/datenuebertragung/laser/odlan/en.html
ODLAN data transmitter systems – which only differ by Signal transmission spectrum (200 kBit/s to 155 Mbit/s) and their maximum distance (400 m to 5000 m) – are built for a safe wireless data transmission between buildings or from a fixed ground station to a mobile crane plant.
The ODLAN series is particularly developed for connection to the Ethernet and is equipped with fiber-optic cable as interface.
ODLAN 95 has a particularly widened divergence, in order that at an uneven crane tracks, communication from the crane to the ground station can be ensured.
