Leaker posts Nvidia RTX 4090 Ti specs
Jan
Who's the Boss?
Staff member
The Rabbit Hole
Monster RTX 4090 Ti specs leaked
Nvidia is planning to launch a monstrous top-of-the-line GeForce RTX 40 graphics card later this year.
That is according to trusted hardware leaker @kopite7kimi, who has dubbed the flagship next-generation card "The Beast".
This is the same guy that said the 4080 and 4090 would launch in July Either NVIDIA is going to have a busy weekend or this guy is like a broken clock.
Noobs can now get owned in 4K 240fps, if eskom can handle that 800W power draw just from the card :ROFL:
If it hadn't been for the Crypto Winter, it very likely would have released in July, but I think Nvidia are scrambling after the crypto winter to sort out their oversupply of components.
Probably closer to R50-60k I would assume.
The 3090Ti is already touching 40K, with this water cooled model already being priced at R45k. A GPU pushing 800W would likely have to be water cooled too, so I assume the price would be stupid.
Ouch, I am out of touch with prices. You make sense though. Now, question, who will buy that? I wont, never.
800W is peak load. TDP is unlikely.
Newer tech less cooling needed per W.
I'm not sure what you mean, you mean they just let the silicon run hotter?
Even then, the current high end cards are already limited by what traditional heat sink and air coolers can handle. 800W per card is like data centre liquid cooling territory.
No the Silicon does not get as hot. Smaller fan needed.
When a 4080 or 4080 Ti is available, then I'll finally upgrade my PC. Until then my Series X will suffice. Hopefully this 4090/4090 Ti nonsense launches simultaneously and not several months before.
