Jola
Just a warning - I have suffered from some damaged LED lights due to using existing (installed) transformers.
The LED lights use much, much less power (typically 3w compared to 50w), and as a result the transformers designed for halogen lights are under such low loads that they output voltages that are too high - LED's suffer damage when the voltage is 13.5 volt or higher.
The problem can be solved by installing, say, 8 or more LED downlighters on a single 20-50w transformer, or by using small 5w transformers where you are using a single light.
Or use GU-10 220v LED lights, then you don't need to use a transformer at all. This works out cheaper and more reliable, in my experience.
But as someone has noted, many LED lights, especially the cheaper solutions, are not as bright as halogens, so make sure that you know what you want.
At the moment I am using 84 LED bulbs to get a reasonable light output for a reasonable cost - the 1 or 3 LED high intensity lights are just too expensive to make economic sense.
