Lenovo T61 : Problem with speaker making static noise
wesleyfraser
Kempton Park
Hi Guys, I hope someone can help.
I am having problems with the sound on my laptop, the sound was working fine last night and when it came out of hibernation today the speakers are making a loud scratch/static noise, when I put the audio on mute it is quiet.
I am running windows xp sp2
I have tried reinstalling the sound max software and audio drivers. Can anyone please help me?
Thanks in advance
well that wipes out magnetic interference from the possible reasons....
you'll have to open it up and give all your connections a good wiggle. its most probably a hardware issue.
You tried a proper restart yet? i.e. not a laptop hibernation style shutdown.
Easiest way to eliminate driver issues would probably be to find a linux live-CD boot from that and see if it does the same thing. (ps live CDs don't remove your windows+data if you just boot from it and don't install).
The laptop is still under warranty so I dont think I should open the laptop just yet. I have a GOs operating system at work so I will give it a try tomorrow. I have restarted, shutdown and still now luck.
I had a sound issue and I did the following:
Went to the actual drivers of the sound card (control panel, sound), speaker<properties> , properties (again), drivers->update drivers. If this does not work, do a driver roll-back and then (if still not working), update. This should work.
I see you posted on Notebookreview's forums and someone suggested updating the soundmax drivers.
I have a Thinkpad T61, too and I don't have this issue, the driver package I am using for XP is version 5.10.1.5520 - also, you can check that your CD volume/line-in/mic is disabled, have you tried that?
Apart from your sound issue, how are you finding your T61 to be?
I am really enjoying the laptop. Well I have tried removing the drivers and reinstalling them, I guess the problem is a little worse now seeing as the sound card is not being picked up in the device manager anymore and I have restarted several times.
You haven't disabled the modem in the BIOS have you? Because they are paired together and if I remember correctly, the soundcard will not be detected if the modem is disabled.
a) Does it sound scratchy in the BIOS?
b) in Windows, does it still sound bad when the master volume is muted?
c) is there still static when it's on batteries?
a) if there's was static in the BIOS then you could rule that it is a hardware issue with the minijack/bad earthing/emi
b) if there is no static when its muted, then it sounds like a driver issue, or you've got your microphone output enabled/midi/etc;
no, by a) I meant in the BIOS, if you left the laptop idling at the BIOS setup, do you hear any static.
I was in the bios for a while and I had no static. But I still cant pick up the sound card when I get into windows. Looks like a trip to my closest Lenovo centre.
